Duo X User Guide
Revision as of 13:20, 6 September 2019 by Leogermani (talk | contribs) (creating page)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Headphone jack
General knob actions
Left knob actions
  • Hold the left knob to access and exit the device menu
Right knob actions
  • Hold the right knob to access and exit the tuner
  • Off: below -30dB
  • Red: above -3dB
Pressing and hold the left endless knob will open the Device Settings menu. Access the Device Settings page to lern how to use it to Load Banks and Pedalboards, adjust volumes and MIDI Settings, manage User profiles and more.
