How To Use Docker Toolbox With MPB
Pre-compiled image
$ git clone --depth 1 git://github.com/moddevices/mod-plugin-builder
$ cd mod-plugin-builder/dockerAfter that you can chose to either create an image for compiling plugins for the DUO, or for the DUO X.
To create a DUO image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduo .Or to create a DUO X image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduox .Note: It will take a very long time...
After it's done, we create a container from mod-plugin-builder by running:
$ docker run -ti --name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder mod-plugin-builder
