How To Use Docker Toolbox With MPB
Pre-compiled image
NOTE: The current pre-compiled image can only compile plugins for the Duo. There will be a new pre-compiled version available soon that can build plugins for both Duo and Duo X. At this moment (May 29th, 2019), there are Docker files available that can build plugins for both platforms but these are not pre-compiled (see section:Full build (advanced, long))
$ git clone --depth 1 git://github.com/moddevices/mod-plugin-builder
$ cd mod-plugin-builder/dockerAfter that you can chose to either create an image for compiling plugins for the DUO, or for the DUO X.
To create a DUO image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduo .Or to create a DUO X image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduox .Note: It will take a very long time...
After it's done, we create a container from mod-plugin-builder by running:
$ docker run -ti --name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder mod-plugin-builder
