Developers
Revision as of 09:47, 24 June 2019 by FalkTX (talk | contribs)
Technical information
As of release 1.1 the MOD Duo runs the Linux kernel version 3.4, with real-time patch. Running in a ARMv7 32bit OS.
SSH is open by default.
The MOD Duo CPU is a dual-core Cortex A7, running at a constant 912 MHz. It is possible to set the speed to 1.0GHz, but with the risk of stability issues.
The MOD Duo X CPU is a quad-core Cortex A53, running at a constant 1.5GHz.
The compiler is GCC 4.9.
And the flags for Duo X are:
Useful links
Please note that it is also possible to build LV2 plugins using DPF or Juce.
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh modduo
$ pushd ~/mod-plugin-builder/
$ source local.env modduo
$ popd
$ make
Quick example plugin
Deploying plugins
APIs and Documentation
For more information see:
JACK
LV2
Toolchain
  • GCC 4.9
  • glibc 2.21
  • binutils 2.25
Libraries
  • acl
  • alsa
  • armadillo
  • audiofile
  • boost
  • cairo
  • dbus
  • expat
  • fftw/fftwf
  • ffmpeg
  • flac
  • fluidsynth
  • fontconfig
  • freetype
  • gio/giomm
  • glib/glibmm
  • glibc (v2.21)
  • icu
  • jack
  • libffi
  • libgig
  • libjpeg/libturbojpeg
  • liblo
  • libogg
  • libpng
  • libsamplerate
  • libsigc
  • libsndfile
  • libvorbis
  • libxml2
  • lilv
  • lvtk (v1 and v2)
  • mxml
  • ncurses
  • ne10
  • pcre
  • pixman
  • python (v3.4)
  • readline
  • sdl
  • serd
  • sord
  • sratom
  • systemd (v219)
  • zita-convolver
  • zita-resampler
Developer mode
This includes:
  • Network statistics
  • Xrun counter (aka audio drop-outs)
   enable_dev_mode()
   disable_dev_mode()
Beta/Unstable plugins
  • For earlier releases, open the browser development console and enter:
Use with caution.
USB Device Support
  • Any regular joystick
Hardware Specification
CPU:
  • Dual Core ARMv7 1.0GHz
  • 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
  • 2 knobs with LCD screen
I/O CONNECTIONS:
