Max gen~
Gen basics
The SHIRO plugins are an example of plugins for the MOD Duo made using this very method.
Designing your effect in Gen
If you want to design a plugin for the MOD Duo, there are a few things you should know:
- To get your gen~ object working on the MOD Duo, you'll need to design one using only Gen's internal objects, without referring to objects outside the gen~ object.
- While designing your gen~ object, remember that the MOD Duo's samplerate is running at 48 kHz.
At this point you should have met the requirements specified above. If so, follow the steps below to get your plugin on the MOD Duo.
- Make sure your MOD Duo is connected, then start the MODwatcher from the popped-up screen.
- If you want your plugin to have a name on the MOD Duo, copy your gen~ objects contents to a gen~ object with a patcher-name argument.
Your plugin will now be transferred to the MOD Duo, within a few minutes the MODwatcher will tell you if the upload succeeded.
Compiling the plugin
First, download http://download.moddevices.com/releases/max-gen/max-gen-deploy_v4.tar.gz and extract it.
Send an "exportcode" message to the gen~ object in your main Max-patcher to get the gen_exported.cpp and gen_exported.h files.
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Editing the plugin
OPTIONAL
$ tar -xzvf Plugin.lv2-duo.tar.gz
$ rm Plugin.lv2-duo.tar.gz
Deploying the plugin
$ ./mod-deploy.sh
