How To Use Docker Toolbox With MPB
Pre-compiled image
note: The current pre-compiled image can only compile plugins for the DUO. There will be a new pre-compiled version available soon that can build plugins for both DUO and DUO X. At this moment(date: May 29th 2019), there are Docker images available that can build plugins for both platforms but these are not pre-compiled(see section:Full build (advanced, long))
$ git clone --depth 1 git://github.com/moddevices/mod-plugin-builder
$ cd mod-plugin-builder/dockerAfter that you can chose to either create an image for compiling plugins for the DUO, or for the DUO X.
To create a DUO image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduo .Or to create a DUO X image run:
$ docker build -t modduox-plugin-builder --build-arg platform=modduox .Note: It will take a very long time...
After it's done, we create a container from mod-plugin-builder by running:
$ docker run -ti --name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder mod-plugin-builder
