MOD SDK
The SDK
Running the SDK
The easiest way to run the MOD SDK is to use its Docker image. This way you dont have to install anything special and bother with complicated environment settings. Simply install docker and run the provided image.
Running the SDK on Windows
2. Choose a folder where you will store your LV2 plugins bundles. In this folder place all the bundles you want to test with the SDK
3. Pull the SDK image from Docker Hub.
Open the Command prompt and type
docker pull moddevices/modsdk
You only need to run this command the first time. It will download the image and store it locally.
4. Once the download is completed, run the following command, replacing the path with the path of the folder where you are storing your LV2 bundles.
docker run -p 9000:9000 -v /c/Users/my-user/my-lv2-folder:/lv2 moddevices/modsdk
In the command above, my chosen folder is C:\Users\my-user\my-lv2-folder. When you run this command, Windows will ask if you give permission to share this folder with Docker. Accept it and continue.
5. Now open your browser and visit localhost:9000
Running the SDK on Linux
Once docker is installed, pull and run the image:
docker run -p 9000:9000 -v /home/my-user/my-lv2-folder:/lv2 moddevices/modsdk
Running the SDK on Mac
Building the SDK
