Developers
Revision as of 23:58, 4 December 2017 by Aspiers (talk | contribs) (→‎Unstable plugins: mention special settings page for accessing unstable plugins)
The MOD Duo runs a highly-optimized Linux embed system, using JACK as audio server and loading plugins in LV2 format.
Plugin parameters can be controlled via the Duo's built-in knobs and footswitches, via MIDI CC and Pitchbend or via Control Chain devices.
Technical information
As of release 1.1 the MOD Duo runs the Linux kernel version 3.4, with real time patch.
ALSA is used for the audio driver. JACK runs inside as audio server backend, with mod-host loading each LV2 plugin as a new (internal) JACK client as mod-ui as the web server.
Useful links
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh
$ make
Quick example plugin
Deploying plugins
To those curious ones, the last command packs the eg-amp.lv2 into a tar.gz file, encodes it as base64 and then sends it to a special URL that the MOD Duo uses to install plugin tarballs.
APIs and Documentation
For more information see:
JACK
LV2
Toolchain
  • GCC 4.9
  • glibc 2.21
  • binutils 2.25
Libraries
  • acl
  • alsa
  • armadillo
  • audiofile
  • boost
  • cairo
  • dbus
  • expat
  • fftw/fftwf
  • ffmpeg
  • flac
  • fluidsynth
  • fontconfig
  • freetype
  • gio/giomm
  • glib/glibmm
  • glibc (v2.21)
  • icu
  • jack
  • libffi
  • libgig
  • libjpeg/libturbojpeg
  • liblo
  • libogg
  • libpng
  • libsamplerate
  • libsigc
  • libsndfile
  • libvorbis
  • libxml2
  • lilv
  • lvtk (v1 and v2)
  • mxml
  • ncurses
  • ne10
  • pcre
  • pixman
  • python (v3.4)
  • readline
  • sdl
  • serd
  • sord
  • sratom
  • systemd (v219)
  • zita-convolver
  • zita-resampler
Developer mode
This includes:
  • Buffer size change (128 or 256 frames)
  • Network statistics
  • Xrun counter
   enable_dev_mode()
   disable_dev_mode()
Unstable plugins
  • For earlier releases, open the browser development console and enter:
Use with caution.
USB Device Support
  • Several USB-MIDI devices
Hardware Specification
CPU:
  • Dual Core ARM A7 1.0GHz
  • 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
  • 2 knobs with LCD screen
I/O CONNECTIONS:
  • USB HOST – USB 2.0 Standard-A type, supporting: USB Bluetooth, USB Wifi, USB MIDI
