How To Make a MPB Package
PLUGINPKG_VERSION = 1.0.0
$(eval $(cmake-package))Let's divide this into small pieces so it's easier to understand.
We're using PLUGINPKG as a generic name, you must use your package name in uppercase here.
PLUGINPKG_SOURCE = myplugin-$(PLUGINPKG_VERSION).tar.gzIf you rather use a git repository, use something like this:
PLUGINPKG_SITE_METHOD = gitMoving on, we define which bundles to use.
PLUGINPKG_BUNDLES = myplugin.lv2Finally, we defined the steps to build the package.
If you're using autoconf or cmake, buildroot has this covered for you already.
For autotools, use:
$(eval $(autotools-package))For cmake, use:
$(eval $(cmake-package))Using other build systems means you have to specify how to configure, build and install the code.
Here's an example for waf:
(cd $(@D); $(BLOP_TARGET_WAF) configure --prefix=/usr)
endef
define PLUGINPKG_BUILD_CMDS
(cd $(@D); $(BLOP_TARGET_WAF) build -j $(PARALLEL_JOBS))
endef
(cd $(@D); $(BLOP_TARGET_WAF) install --destdir=$(TARGET_DIR))
endef
$(eval $(generic-package))And here's an example for raw makefiles:
$(PLUGINPKG_TARGET_MAKE)
endef
endef
$(eval $(generic-package))Tips and tricks
PLUGINPKG_CONF_OPTS=-DBUILD_GUI=OFFPLUGINPKG_AUTORECONF = YESPLUGINPKG_MAKE = $(MAKE1)Final notes
A few important notes:
- If you want to rebuild after a change to your plugin or the .mk then it is often easiest to just delete the previous build's directory for your plugin ~/mod-workdir/plugins-dep/build/<packagename>-<version>
