How To Make a MPB Package
Revision as of 21:17, 13 September 2017 by FalkTX (talk | contribs)
A few important notes:
  • The package name is defined by the folder name and cannot contain '.'
  • There must be a <packagename>.mk file inside the package folder
  • The package name and '.mk' file name must be the same
  • Inside the '.mk' file all defined variables must start with the package name in uppercase replacing '-' with '_'
  • You need to define the generated plugin bundle names in the <PACKAGE_NAME>_BUNDLES variable
  • Browse through other examples so you get an idea of other variations of the makefiles (how to use cmake or waf for example)
  • If you want to rebuild after a change to your plugin or the .mk then it is often easiest to just delete the previous build's directory for your plugin ~/mod-workdir/plugins-dep/build/<packagename>-<version>
# abgate
ABGATE_VERSION = 1.1.7
ABGATE_SITE = http://download.sourceforge.net/abgate/
ABGATE_SOURCE = abGate-$(ABGATE_VERSION).tar.gz
ABGATE_BUNDLES = abGate.lv2
ABGATE_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE) -C $(@D)
define ABGATE_BUILD_CMDS
	$(ABGATE_TARGET_MAKE)
endef
define ABGATE_INSTALL_TARGET_CMDS
	$(ABGATE_TARGET_MAKE) install DESTDIR=$(TARGET_DIR)
	cp -rL $($(PKG)_PKGDIR)/abGate.lv2/* $(TARGET_DIR)/usr/lib/lv2/abGate.lv2/
endef
$(eval $(generic-package))
