Troubleshooting Reinstall
- Turn off your MOD
- Disconnect the USB cable
Reinstalling the bootloader will keep all data intact, but if the issue is somewhere else the MOD will continue to not boot.
This is the best option, if it works.
Reinstalling the system over USB only works on Linux at the moment.
Reinstall bootloader
If you're running macOS, run:
./bootfix.osx
./bootfix
Factory Reset
Continuing:
Reinstall via USB boot
Continuing:
- Run:
./boot-fel-restore.sh
- Wait for around 2 minutes, and the MOD Duo will boot into recovery mode.
