Troubleshooting Reinstall
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
  7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  8. Disconnect the USB cable
Reinstalling the bootloader will keep all data intact, but if the issue is somewhere else the MOD will continue to not boot.
Factory Reset
If you're running macOS, run:
Continuing:
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/tools/mod-boot-fel-restore.tar.gz and extract it
Continuing:
  1. Run: ./boot-fel-restore.sh
