Max gen~
Revision as of 19:35, 26 July 2017 by Ninoshiro (talk | contribs) (Edits for the Max-package)
Gen Basics
The SHIRO plugins are an example of audio effects made using this very method.
Designing your effect in Gen
  • To get your gen~ object working on the MOD Duo, you'll first need to design one using only Gen's internal objects, without referring to objects outside the gen~ object. Only the objects inside will make it to the final LV2-plugin.
  • If you want controllable parameters, define the default, minimum and maximum arguments in the "param" object.
  • While designing your gen~ object, remember that the MOD Duo's samplerate is running at 48 kHz.
If you download the MOD Duo-package from the Package Manager in Max and click on Launch, you'll find some example-plugins.
At this point you should have met the requirements specified above. If so, follow the steps below to get your plugin on the MOD Duo.
  • Go to or install the MOD Duo-package in the Package Manager in Max if you haven't, and click on Launch.
  • Make sure your MOD Duo is connected, then start the MODwatcher from the popped-up screen.
  • If you want your plugin to have a name on the MOD Duo, copy your gen~ objects contents to a gen~ object with a patcher-name argument.
    NAMING YOUR ORIGINAL GEN~ OBJECT WILL INITIALIZE IT'S CONTENTS
  • Finally send a message containing "exportnotifier MODwatcher, exportcode" (without the quotation marks) to the gen~ object.
Your plugin will now be transferred to the MOD Duo, within a few minutes the MODwatcher will tell you if the upload succeeded.
Compiling the plugin
First, download http://download.moddevices.com/releases/max-gen/max-gen-deploy_v4.tar.gz and extract it.
Send an "exportcode" message to the gen~ object in your main Max-patcher to get the gen_exported.cpp and gen_exported.h files.
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Editing the plugin
To add units, knob behavior or a description, you'll have to edit the .ttl file. If you do so, make sure everything is correct,
OPTIONAL
$ tar -xvf Plugin.lv2-duo.tar
$ rm Plugin.lv2-duo.tar.gz
Deploying the plugin
$ ./mod-deploy.sh
