Troubleshooting Reinstall
- Turn off your MOD
- Disconnect the USB cable
Factory Reset
- Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.4.1.459-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.4.1.459-reset-image.raw
(adjust the path to 'modduo-v1.4.1.459-reset-image.raw' as needed)
./bootfix -w ~/Downloads/modduo-v1.4.1.459-reset-image.raw
(adjust the path to 'modduo-v1.4.1.459-reset-image.raw' as needed, sudo will likely be needed here)
Continuing:
Reinstall via USB boot
Continuing:
- Run:
