Max gen~
Gen Basics
The SHIRO plugins are an example of audio effects made using this very method.
Designing your effect in Gen
- To get your gen~ object working on the MOD Duo, you'll first need to design one using only Gen's internal objects, without referring to objects outside the gen~ object. Only the objects inside will make it to the final LV2-plugin.
- While designing your gen~ object, remember that the MOD Duo's samplerate is running at 48 kHz.
When you're finished, send the "exportcode" message to the gen~ object in your main Max-patcher to get the gen_exported.cpp and gen_exported.h files.
At this point you should have the exported code from your gen~ object, and have met the requirements specified above.
If so, follow the steps below to get your plugin on the MOD Duo.
Compiling the plugin
First, download http://download.moddevices.com/releases/max-gen/max-gen-deploy_v4.tar.gz and extract it.
$ cd /path/to/max-gen-deploy/
Deploying the plugin
$ ./mod-deploy.shIf all goes well, your Gen-based plugin should now be inside the MOD Duo, ready to be played!
Optionally you can edit the ttl files to, for example, add units, knob behavior or a description.
If you do so, make sure everything is correct, otherwise the plugin won't work and you might have to SSH into the MOD Duo to get the corrupt plugin out.
OPTIONAL
$ tar -xvf Plugin.lv2-duo.tar
$ rm Plugin.lv2-duo.tar.gz
$ tar -cvzf Plugin.lv2-duo.tar.gz Plugin.lv2/Another option is to include a GUI, you can make one with the MOD SDK.
And don't forget to compress everything again and redeploy.
