Troubleshooting Reinstall
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
  7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  8. Disconnect the USB cable
Factory Reset
  4. Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.3.2.394-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.3.2.394-reset-image.raw
./bootfix -w ~/Downloads/modduo-v1.3.2.394-reset-image.raw
Continuing:
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/tools/mod-boot-fel-restore.tar.gz and extract it
Continuing:
  1. Run: ./boot-fel-restore.sh
