Troubleshooting Reinstall via LiveSuit
Revision as of 15:13, 23 June 2017 by FalkTX (talk | contribs)
  1. Click and hold down the FEL button on the back of the MOD Duo (in tiny hole), while you power it on
  4. Download http://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
  5. Install the FEL mode Windows driver (see #Installing FEL mode USB driver section below)
  6. Run LiveSuit and deploy the MOD Duo LiveSuit image (see #Deploying LiveSuit image below)
  7. Wait for the Duo's restore mode to activate
  8. Download http://download.moddevices.com/releases/testing/modduo-v1.4.0.432-RC5.tar and copy it to the mass storage device (as usual for MOD updates)
  9. Wait until the installation finishes (the Duo will automatically reboot)
2. Download http://download.moddevices.com/releases/modduo/tools/modduo_livesuit_restore.img
3. Click on the 'Upgrade' button or replug the USB cable that connects the MOD Duo to your PC (without taking off the power cable).
When asked about a forced format, click 'yes'
