Troubleshooting Reinstall via LiveSuit
- Download http://download.moddevices.com/releases/modduo/tools/PhoenixSuit1.0.7.zip and extract its contents
- Run LiveSuit and deploy the MOD Duo LiveSuit image (see Deploying LiveSuit image below)
- Download http://download.moddevices.com/releases/modduo/testing/modduo-v1.4.0.432.tar and copy it to the mass storage device (as usual for MOD updates)
2. Download...
3. When asked about a forced format, click 'yes'.
