Max gen~
Revision as of 14:41, 23 June 2017 by FalkTX (talk | contribs)
Gen Basics
Designing your effect in Gen
  • To get your gen~ object working on the MOD Duo, you'll first need to design one using only Gen's internal objects, without referring to objects outside the gen~ object. Only the objects insides will make it to the final LV2-plugin.
  • If you want controllable parameters, define the minimum, maximum and default arguments in the "param" object.
  • While designing your gen~ object, remember that the MOD Duo's samplerate is running at 48 KhZ.
Compiling the plugin
First, download http://download.moddevices.com/releases/max-gen/max-gen-deploy_v4.tar.gz and extract it. Copy the gen_exported.cpp and gen_exported.h files into the extracted max-gen-deploy folder, and run:
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Deploying the plugin
$ ./mod-deploy.sh
Optionally you can edit the ttl files to, for example, add units, knob behavior or a description. If you do so, make sure everything is correct, otherwise the plugin won't work and you might have to SSH into the MOD Duo to get the corrupt plugin out. To prevent this from happening, you can validate the lv2-data.
OPTIONAL
$ tar -xvf Plugin.lv2-duo.tar
$ rm Plugin.lv2-duo.tar.gz
Another option is to include a GUI, you can make one with the MOD SDK.
And don't forget to compress everything again and redeploy.
