Troubleshooting Reinstall via LiveSuit
Installing MOD Duo via LiveSuit
WIP notes only
mention tool is not made by MOD
needs driver install
mod needs to be disconnected before starting livesuit?
Installing FEL mode USB driver
Deploying LiveSuit image
1. Double-click on the PhoenixSuit file to open it. The application looks like this:
2. Download...
Click on the Firmware tab.
Click on the 'browse' button and ...
3. When asked ..., click 'yes'.
The MOD Duo will automatically boot into restore mode after the deploy.
Grab the latest release image from [Releases] and copy it to the mass storage device as usual for MOD updates.
Note that for LiveSuit deploys, version 1.4 or higher is required.
