Max gen~
This quick start guide will tell you the how and why of programming audio effects for the MOD Duo using this very different approach.
Gen Basics
Designing your effect in Gen
- To get your gen~ object working on the MOD Duo, you'll first need to design one using only Gen's internal objects, without referring to objects outside the gen~ object. Only the objects insides will make it to the final LV2-plugin.
- While designing your gen~ object, remember that the MOD Duo's samplerate is running at 48 KhZ.
Compiling the plugin
$ cd /path/to/max-gen-deploy/
Deploying the plugin
$ ./mod-deploy.shIf all goes well, your Gen-based plugin should now be inside the MOD Duo, ready to be played!
Optionally you can edit the ttl files to, for example, add units, knob behavior or a description. If you do so, make sure everything is correct, otherwise the plugin won't work and you might have to SSH into the MOD Duo to get the corrupt plugin out. To prevent this from happening, you can validate the lv2-data.
OPTIONAL
$ tar -xvf Plugin.lv2-duo.tar
$ rm Plugin.lv2-duo.tar.gz
$ tar -cvzf Plugin.lv2-duo.tar.gz Plugin.lv2/Another option is to include a GUI, you can make one with the MOD SDK.
And don't forget to compress everything again and redeploy.
