Max gen~
Apart from programming LV2-plugins in a "traditional" way, it's also possible to generate LV2-plugins for the MOD Duo from gen~ objects created in Cycling '74 Max. This quick start guide will tell you the how and why of programming audio effects for the MOD Duo using this very different approach.
Gen Basics
Gen~ objects are normally used in Max as a way to write low-level code that is run at signal-rate, using (if you want to) the same visual approach Max is known for. Therefore the insides of a gen~ object can be seen as a pedal schematic, perfect for designing audio effects.
Designing your effect in Gen
- To get your gen~ object working on the MOD Duo, you'll first need to design one using only Gen's internal objects, without referring to objects outside the gen~ object. Only the objects insides will make it to the final LV2-plugin.
- While designing your gen~ object, remember that the MOD Duo's samplerate is running at 48 KhZ.
Compiling the plugin
$ cd /path/to/max-gen-deploy/
$ ./mod-build.sh
Edit the .ttl file (optional)
Optionally you can now edit the .ttl file to for example add units, knob behavior or a description. If you do so, make sure everything is correct, otherwise the plugin won't work and you might have to SSH into the MOD Duo to get the corrupt plugin out. To prevent this from happening, you can validate the lv2-data.
OPTIONAL
$ tar -xvf Plugin.lv2-duo.tar
$ rm Plugin.lv2-duo.tar.gz
Include a GUI (optional, advanced)
Another option is to include a GUI, you can make one with the MOD SDK. Have a look here how a GUI affects the .ttl structure. And don't forget to compress everything again.
Deploying the plugin
Make sure the MOD Duo is connected to your computer via USB before proceeding.
$ mod-deploy.sh
$ mod-deploy.sh
