MOD Duo User Guide
Audio inputs
Audio outputs
Headphone output
Power input
Control chain
USB-A host
USB-B slave
DIN-MIDI
General knob actions
Left knob actions
Right knob actions
General footswitch actions
- width: 180 mm
- length: 160 mm
- height: 74.7 mm
Audio flow
The graphic below represents the signal-flow of the audio inside the MOD Duo.
Please note the position where the LED meters read from.
- Off: below -30dB
- Red: above -3dB
Important conclusions:
- The input gains accessible via the menu - both stage and fine adjust - determine the level of the analog signal coming to the ADC. This is 100% analog.
- The output volume accessible via the menu does not affect the running pedalboard and can't help in case it is clipping. You can solve clipping by reducing the volume inside the pedalboard.
Current pedalboard
Volume and gains
- Low: -22.0 dBu
- Medium: -9.5 dBu
- High: +3.0 dBu
For more information about Bluetooth, see its dedicated section [Bluetooth here].
- jack
- mod-host
- mod-ui
- ttymidi
- release
- restore (hexadecimal)
- system (hexadecimal)
- controller (hexadecimal)
Hooking up the MOD Duo
Wiring examples
Guitar
- semi-accoustic setup
Vocals
- MIC -> MOD -> DI -> PA
Keys
- HW Synth -> MOD
- ePiano -> MOD
- keyboard -> MOD
- MIDI Grid-controller -> MOD
Exotic
TODO: Add exotic use cases
- Chapman stick
- Wind instruments
- Accoustic instruments
