Main Page
Revision as of 16:46, 21 November 2016 by Jesseverhage (talk | contribs)
Documentation
Check out our (work in progress) Manual for detailed information on the MOD Duo.
Please check the Quick Start Guide to start using the MOD Duo.
Plugin Development
Quick version:
FAQ
A: Connect the MOD Duo to your PC, open your browser and navigate to "192.168.51.1".
Q: Can I hook up USB-MIDI devices? A: You can hook up external MIDI controllers to the MIDI-IN port or USB-A port. If USB-MIDI is used, the device ports need to be added through the web interface.
Q: Can I hook up multiple USB-MIDI devices? A: Yes! Simply add a USB-hub to the USB-A port on the back of the MOD Duo, and plug your USB-MIDI devices into the hub.
Support
