Max gen~
Revision as of 13:22, 28 October 2016 by FalkTX (talk | contribs)
How it works
Based on that project was made DPF-Max-Gen, which uses the much simpler (and limited) DPF instead of Juce.
DPF-Max-Gen
The most important part is the 'plugins' folder. Inside it there's more folders, each containing a separate plugin (with the exception of 'common', which provides the common/base code for gen~).
  • DistrhoPluginInfo.h
  • DistrhoPluginMaxGen.cpp
  • Makefile
  • gen_exported.cpp
  • gen_exported.h
  • gen~.bitcrush.maxpat
DistrhoPluginInfo.h is a C header file, required by DPF, that describes some plugin meta-data.
This includes name, author, description, LV2 URI and the amount of audio channels.
Modify this file as needed. Remember that LV2 URIs are global and unique, and don't have to be real online URLs.
DistrhoPluginMaxGen.cpp is a symlink to the real DistrhoPluginMaxGen.cpp file located in the common folder.
This symlink is here so that we compile a different instance per plugin, but the actual code is the same.
Do not modify this file.
Makefile contains the build rules for compiling the plugin.
The only thing that needs change here is the 'NAME' parameter, which specifies the target LV2 bundle and binary name for the plugin.
