Max gen~
Revision as of 13:13, 28 October 2016 by FalkTX (talk | contribs)
How it works
Based on that project was made DPF-Max-Gen, which uses the much simpler (and limited) DPF instead of Juce.
DPF-Max-Gen
The most important part is the 'plugins' folder. Inside it there's more folders, each containing a separate plugin (with the exception of 'common', which provides the common/base code for gen~).
