How To Use Docker Toolbox With MPB
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics (Pre-compiled image)
$ docker start -i mpbDocker Advanced (Full build)
If you don't want to use a pre-compiled image, you can build mod-plugin-builder yourself. To begin, start docker and run:
$ git clone --depth 1 git://github.com/moddevices/mod-plugin-builder
$ docker build -t mod-plugin-builder .Note: It will take a very long time...
After it's done, we create a container from mod-plugin-builder by running:
$ docker run -ti --name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder mod-plugin-builder
