How To Use Docker Toolbox With MPB
Revision as of 13:07, 18 August 2016 by FalkTX (talk | contribs)
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
Some notes:
$ docker start -i mpb
Docker Advanced
If you don't want to use a pre-compiled image, you can build mod-plugin-builder yourself. To begin, start docker and run:
$ git clone --depth 1 git://github.com/moddevices/mod-plugin-builder
$ docker build -t mod-plugin-builder .
Note: It will take a very long time...
After it's done, we create a container from mod-plugin-builder by running:
$ docker run -ti --name mpb -p 9000:9000 -v ~/local-mod-folder:/tmp/local-mod-folder mod-plugin-builder
$ exit
That's it, the commend to start the mod-plugin-builder environment is now:
