How To Use Docker Toolbox With MPB
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
Some notes:
$ docker start -i mpb
Docker Advanced
If you don't want to use a pre-compiled image, you can build mod-plugin-builder yourself. To begin, start docker and run:
$ docker run --rm -ti --name mpb -p 9000:9000 mpb
$ docker run --rm -ti --name mpb -p 9000:9000 -v /path/to/docker/files:/tmp/mbs mpb
Without closing the console window, run the following to start building mod-plugin-builder:
$ cd mod-plugin-builder
$ ./bootstrap.sh
