How To Use Docker Toolbox With MPB
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
$ docker run -ti --name mpb moddevices/mod-plugin-builderIf you wish to have a local folder accessible inside the docker environment, use the '-v' argument with the local and docker mapped folder joined by a semi-colon. Like this:
$ docker run -ti --name mpb -v ~/local-mod-folder:/tmp/local-mod-folder moddevices/mod-plugin-builderSome notes:
$ docker start -i mpb
