How To Use Docker Toolbox With MPB
Revision as of 11:33, 25 May 2016 by FalkTX (talk | contribs)
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
$ docker run -ti --name mpb moddevices/mod-plugin-builder
$ docker run -ti --name mpb -v ~/local-mod-folder:/tmp/local-mod-folder moddevices/mod-plugin-builder
Some notes:
$ docker start -i mpb
