How To Use Docker Toolbox With MPB
Revision as of 11:25, 25 May 2016 by FalkTX (talk | contribs)
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
$ docker run -ti moddevices/mod-plugin-builder -l mpb
$ docker run -ti moddevices/mod-plugin-builder -l mpb -v ~/local-mod-folder:/tmp/local-mod-folder
Some notes:
$ docker start -i mpb
