How To Use Docker Toolbox With MPB
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
To begin we download the pre-compiled mod-plugin-builder docker image, by running:
$ docker run -ti moddevices/mod-plugin-builder -l mpb
$ docker run -ti moddevices/mod-plugin-builder -l mpb -v ~/local-mod-folder:/tmp/local-mod-folder
Some notes:
$ docker start -i mpb
