How To Use Docker Toolbox With MPB
We'll be using Docker Toolbox for this.
So before we begin please install that first.
Docker Basics
All we need to do is download the pre-compiled mod-plugin-builder docker image, by running:
$ docker run -ti moddevices/mod-plugin-builder -l mpbIf you wish to have a local folder accessible inside the docker environment, use the '-v' argument with the local and docker mapped folder joined by a semi-colon. Like this:
$ docker run -ti moddevices/mod-plugin-builder -l mpb -v ~/local-mod-folder:/tmp/local-mod-folderSome notes:
$ docker start -i mpbYou can find more information about docker here.
