LV2 Basics
Prepare build tools
In order to run a plugin in the MOD Duo we must compile it for its specific architecture.
The Duo uses an ARMv7 processor running a very basic and stripped-down version of Linux. Several audio-related libraries are included (fftw, libsndfile, libresample, etc) as well as generic libraries (boost, eigen, qt5core, etc).
We currently provide a custom build system that gives developers a similar system to what's available inside the Duo. Do not use the regular Linux system, it might lead to issues due to mismatching library versions.
Just clone MOD Plugin Builder and follow the instructions.
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.shThis process should take at least 1 hour, probably more depending on your CPU. When it finishes you'll be able to build plugins for Duo.
Using docker
Alternatively, if you're familiar with docker or are not running Linux, you can also use our mod-plugin-builder image which includes a fully built system. The only command you need is:
$ docker run -ti moddevices/mod-plugin-builderGet source code and create a '.mk' file
In case you haven't started your LV2 plugin yet just please follow through the links above in #LV2 Basics. We have a few plugin examples available here. For this guide we'll use the eg-amp.lv2 example.
The documentation for this file type is quite extensive, so it's not possible to cover everything here. On the mod-plugin-builder repository (that you should have cloned before) there are many mk file examples under plugins/package/.
Compile it
We're all set to compile.
$ cd ~/mod-plugin-builder/
$ ./build eg-amp-lv2
$ ls ~/mod-workdir/plugins/
eg-amp.lv2Success, the plugin has been built.
Deploy it
$ modsdkThen open a browser at localhost:9000, select a plugin from the list and use the "deploy" tab to push the selected plugin's bundle to the Duo.
$ cd ~/mod-workdir/plugins/
$ tar czf eg-amp.tgz eg-amp.lv2
$ cat eg-amp.tgz | base64 | curl -F 'package=@-' http://192.168.51.1/sdk/installFew things about the build script and Buildroot
A few important notes:
The '.mk' file will define how your source code is retrieved. In most of the existing packages the '.mk' file tells buildroot to download the source. You can use a local tarball or point directly to the source code if you wish.
Just replace the top section with the following:
<PACKAGE_NAME>_SITE = /path/to/sourceMake sure to remove the <PACKAGE_NAME>_SOURCE line, if it exists.
If you try changing the eg-amp-lv2 example don't forget to remove the trailing path from the make command. It should look like this:
<PACKAGE_NAME>_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE) -C $(@D)If you place the source code in same folder as the '.mk' file you can set the <PACKAGE_NAME>_SITE like this:
<PACKAGE_NAME>_SITE = $($(PKG)_PKGDIR)/You can find a working example of such setup here.
Point to a local tarball
If you make a tar.gz file and put it in the same folder as the '.mk' file, you can replace the top section with the following:
<PACKAGE_NAME>_VERSION = 1.0
<PACKAGE_NAME>_SOURCE = eg-amp-1.0.tar.gzIf you want to use an arbitrary path just replace the <PACKAGE_NAME>_SITE variable.
