Revision as of 09:54, 25 May 2016 by FalkTX (talk | contribs)
LV2 Basics
Prepare build tools
In order to run a plugin in the MOD Duo we must compiled it for its specific architecture.
The Duo uses an ARMv7 processor running a very basic and stripped-down version of Linux. Several audio-related libraries are included (fftw, libsndfile, libresample, etc) as well as generic libraries (boost, eigen, qt5core, etc).
We currently provide a custom build system that gives developers a similar system to what's available inside the Duo. (Using a regular Linux system might lead to issues due to mismatching library versions.)
Just clone MOD Plugin Builder and follow the instructions.
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh
This process should take at least 1 hour, probably more depending on your CPU. When it finishes you'll be able to build plugins for Duo.
Using docker
Alternatively, if you're familiar with docker or are not running Linux, you can also use our mod-plugin-builder image which includes a fully built system. The only command you need is:
$ docker run -ti moddevices/mod-plugin-builder
Get source code and create a .mk file
In case you haven't started your LV2 plugin yet just please follow through the links above in [[#LV2 Basics] LV2 Basics]. We have a few plugin examples available here. For this guide we'll use the eg-amp.lv2 example.
Assuming you have a working LV2 plugin code, you'll now need to create a buildroot mk file to build it. Buildroot requires you to create the new mk file as plugins/package/NAME/NAME.mk - using the same name for both the folder and mk file.
The documentation for this file type is quite extensive, so it's not possible to cover everything here. On the mod-plugin-builder repository (that you should have cloned before) there are many mk file examples under plugins/package/.
Compile it
We're all set to compile.
$ cd ~/mod-plugin-builder/
$ ./build eg-amp-lv2
$ ls ~/mod-workdir/plugins/
eg-amp.lv2
Success, the plugin has been built.
Deploy it
$ modsdk
Then open a browser at localhost:9000, select a plugin from the list and use the "deploy" tab to push the selected plugin's bundle to the Duo.
$ cd ~/mod-workdir/plugins/
$ tar czf eg-amp.tgz eg-amp.lv2
$ cat eg-amp.tgz | base64 | curl -F 'package=@-' http://192.168.51.1/sdk/install
Few things about the build script and Buildroot
A few important notes:
  • The package name is defined by the folder name and cannot contain '.'
  • There must be a <packagename>.mk file inside the package folder
  • The package name and '.mk' file name must be the same
  • Inside the '.mk' file all defined variables must start with the package name in uppercase replacing '-' with '_'
  • Browse through other examples so you get an idea of other variations of the makefiles (how to use cmake or waf for example)
  • You need to define the generated plugin bundle names in the _BUNDLES
The .mk file will define how your source code is retrieved. In most of the existing packages the '.mk' file tells buildroot to download the source. You can use a local tarball or point directly to the source code if you wish.
Just replace the top section with the following:
<PACKAGE_NAME>_SITE = /path/to/source
Make sure to remove the <PACKAGE_NAME>_SOURCE line, if it exists.
If you try changing the eg-amp-lv2 example don't forget to remove the trailing path from the make command. It should look like this:
<PACKAGE_NAME>_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE) -C $(@D)
If you place the source code in same folder as the .mk file you can set the <PACKAGE_NAME>_SITE like this:
<PACKAGE_NAME>_SITE = $($(PKG)_PKGDIR)/
You can find a working example of such setup here.
Point to a local tarball
If you make a tar.gz file and put it in the same folder as the .mk file, you can replace the top section with the following:
<PACKAGE_NAME>_VERSION = 1.0
<PACKAGE_NAME>_SOURCE = eg-amp-1.0.tar.gz
If you want to use an arbitrary path just replace the <PACKAGE_NAME>_SITE variable.
