LV2 Basics
Prepare build tools
In order to run a plugin in the MOD Duo we must compiled it for its specific architecture.
The Duo uses an ARMv7 processor running a very basic and stripped-down version of Linux. Several audio-related libraries are included (fftw, libsndfile, libresample, etc) as well as generic libraries (boost, eigen, qt5core, etc).
We currently provide a custom build system that gives developers a similar system to what's available inside the Duo. (Using a regular Linux system might lead to issues due to mismatching library versions.)
Just clone MOD Plugin Builder and follow the instructions.
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.shThis process should take at least 1 hour, probably more depending on your CPU. When it finishes you'll be able to build plugins for Duo.
Using docker
Alternatively if you're familiar with docker you can also use our mod-plugin-builder image which already includes a fully built SDK. The only command you need is:
$ docker run -ti moddevices/mod-plugin-builderGet source code and create a .mk file
In case you haven't started your LV2 plugin yet just please follow through the links above in [[#LV2 Basics] LV2 Basics]. We have a few plugin examples available here. For this guide we'll use the eg-amp.lv2 example.
The documentation for this file type is quite extensive, so it's not possible to cover everything here. On the mod-plugin-builder repository (that you should have cloned before) there are many mk file examples under plugins/package/.
Compile it
We're all set to compile.
$ cd ~/mod-plugin-builder/
$ ./build eg-amp-lv2
$ ls ~/mod-workdir/plugins/
eg-amp.lv2Success, the plugin has been built.
Deploy it
$ modsdkThen open a browser at localhost:9000, select a plugin from the list and use the "deploy" tab to push the selected plugin's bundle to the Duo.
$ cd ~/mod-workdir/plugins/
$ tar czf eg-amp.tgz eg-amp.lv2
$ cat eg-amp.tgz | base64 | curl -F 'package=@-' http://192.168.51.1/sdk/installFew things about the build script and Buildroot
A few important notes:
- Inside the .mk file all defined variables must start with the package name replacing '-' with '_'
- Browse through other examples so you get an idea of other variations of the makefiles (how to use waf for example)
- If your code has dependencies you need to fill in the _BUNDLES variable with a list; you can check the available packages here
The .mk file will define how your source code is retrieved. In the eg-amp example the .mk file tells Buildroot to download it from github. Alternatively you can use a local tarball or point directly to the source code.
Just replace the top section called 'download source code' with the following:
<PACKAGE_NAME>_SITE = /path/to/sourceIt's important that you replace the section, a _VERSION variable cannot exist or it will fail. If you try changing the eg-amp example don't forget to remove the trailing path from the make command. It should look like this:
<PACKAGE_NAME>_TARGET_MAKE = $(TARGET_MAKE_ENV) $(TARGET_CONFIGURE_OPTS) $(MAKE) -C $(@D)If you place the source code in same folder as the .mk file you can set the _SITE using $($(PKG)_PKGDIR)/ as a relative path.
You can find a working example of such setup here.
Point to a local tarball
Assuming you make a tar.gz file and put it in the same folder as the .mk file then you must replace the top section called 'download source code' with the following:
<PACKAGE_NAME>_VERSION = 1.0
<PACKAGE_NAME>_SITE = $($(PKG)_PKGDIR)
<PACKAGE_NAME>_SOURCE = eg-amp-$(<PACKAGE_NAME>_VERSION).tar.gzIf you want to use an arbitrary path just replace the _SITE variable.
