Revision as of 05:54, 4 May 2016 by Alercunha (talk | contribs)
In order to have a LV2 plugin running in a MOD Device you'll need the following:
  1. Understand the very basics of LV2
  2. Create a new LV2 plugin
  3. Get the build tools
  4. Create your project make files
  5. Compile it
  6. Deploy it
  7. Publish it
Let's dive in.
Basics of LV2
TODO: add samples
Get the build tools
A LV2 plugin is just a binary. However to run in a MOD Device it must be compiled using a cross-compiler targeting that particular hardware and software (libraries). Luckily this process has been made easy. All you need is to clone MOD Plugin Builder and follow the instructions.
$ ./bootstrap.sh
A few notable packages that you'll need:
  • gperf
  • makeinfo
  • texinfo
  • libtool
  • automake
  • libncurses5-dev
Once finished you should have the cross compiler installed in ~/mod-workdir.
$ ls ~/mod-workdir
$ build download toolchain
mod-plugin-builder is based on Buildroot which requires you to create make files that indicate how you plugin should be built. You must have a {projectname}.mk file in mod-plugin-builder/plugins/package/{projectname} folder.
