Revision as of 05:14, 4 May 2016 by Alercunha (talk | contribs)
In order to have a LV2 plugin running in a MOD Device you'll need the following:
  1. Understand the very basics of LV2
  2. Create a new LV2 plugin
  3. Get the build tools
  4. Bootstrap your project
  5. Compile it
  6. Deploy it
  7. Publish it
Let's dive in.
Basics of LV2
TODO: add samples
Get the build tools
A LV2 plugin is just a binary. However to run in a MOD Device it must be compiled for that particular hardware and software (libraries). This mean you'll have to use a custom compiler called MOD Plugin Builder which takes care of that process for you.
Just follow the instructions to get it installed and running.
