NEWMOD Web GUI User Guide
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Getting Started
To access the Web GUI:
Navigating the Interface
Web GUI Layout
  • Pedalboard View – Visual representation of your signal chain
  • Plugins Bar – List of installed plugins that can be dragged into the pedalboard
  • Banks & Snapshots – Quick access to saved pedalboards
  • Store – Plugin store where you can install new effects and utilities
  • System Status & Settings – Access system settings, monitor CPU usage, and adjust device preferences
  1. Explanation of each main interface section (Pedalboard, Banks, Store, etc.).
  1. Creating a new pedalboard.
  2. Adding and connecting plugins.
  3. Using gain staging & meter plugins.
  4. Saving & managing pedalboards.
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
