NEWMOD Web GUI User Guide
- 1 Introduction
- 2 Navigating the Interface
- 6 Plugin Management & Store
- 7 File Handling
- 8 CV Usage & Modulation
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Getting Started
To access the Web GUI:
MOD Duo: http://modduo.local or http://192.168.51.1 MOD Duo X: http://modduox.local or http://192.168.51.1 MOD Dwarf: http://moddwarf.local or http://192.168.51.1 MOD Desktop: http://127.0.0.1:18181/ Bluetooth connection: http://192.168.50.1 (See Bluetooth Setup for details)
[#3] Start building and customizing your setup!
- Overview of Web GUI layout.
- Creating a new pedalboard.
- Adding and connecting plugins.
- Using gain staging & meter plugins.
- Saving & managing pedalboards.
- MIDI learn and mapping.
- Installing new plugins.
File Handling
- True Bypass feature.
- Common connection issues.
