NEWMOD Web GUI User Guide
What is the MOD Web GUI?
How Does It Work?
Compatible Devices
Getting Started
To access the Web GUI:
     MOD Duo: http://modduo.local or http://192.168.51.1
     MOD Duo X: http://modduox.local or http://192.168.51.1
     MOD Dwarf: http://moddwarf.local or http://192.168.51.1
     MOD Desktop: http://127.0.0.1:18181/
     Bluetooth connection: http://192.168.50.1 (See Bluetooth Setup for details)
  1. 3 Start building and customizing your setup!
Navigating the Interface
  1. Overview of Web GUI layout.
  2. Explanation of each main interface section (Pedalboard, Banks, Store, etc.).
  1. Creating a new pedalboard.
  2. Adding and connecting plugins.
  3. Using gain staging & meter plugins.
  4. Saving & managing pedalboards.
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
