NEWMOD Web GUI User Guide
What is the MOD Web GUI?
The MOD Web GUI is a powerful, browser-based interface that allows you to: - Create and manage pedalboards using a fully modular approach. - Install, remove, and organize plugins from the MOD Plugin Shop. - Assign physical controls (knobs, footswitches, MIDI devices, etc.) to parameters for hands-free operation. - Save and organize banks & snapshots for seamless performance transitions. - Adjust system settings, monitor CPU usage, and update your device firmware.
How Does It Work?
MOD devices run a dedicated audio engine that includes an embedded web server. This web server hosts the MOD Web GUI, which can be accessed from a web browser on a connected computer. The engine processes audio in real-time while allowing users to visually configure and manipulate their signal chain via the Web GUI. For hardware devices (MOD Duo, Duo X, and Dwarf), the web server runs inside the device itself. Users connect to it over a network (via USB, Ethernet, or Bluetooth) to access the interface. For MOD Desktop, the MOD audio engine and web server both run on the same computer as the web browser, allowing direct access to the Web GUI without external connections. Despite this difference, the underlying topology remains the same across all platforms.
  1. Explanation of different MOD devices & MOD Desktop.
  2. High-level summary of features.
Navigating the Interface
  1. Overview of Web GUI layout.
  2. Explanation of each main interface section (Pedalboard, Banks, Store, etc.).
  1. Creating a new pedalboard.
  2. Adding and connecting plugins.
  3. Using gain staging & meter plugins.
  4. Saving & managing pedalboards.
  2. MIDI learn and mapping.
Managing Banks & Snapshots
Plugin Management & Store
  1. Installing new plugins.
File Handling
CV Usage & Modulation
Advanced Features & Settings
  1. True Bypass feature.
Troubleshooting & Support
  1. Common connection issues.
