MOD Duo X Technical Specs
Technical specs
- length: 188 mm
- width: 163 mm
- height: 63 mm
Processors
- RockChip RK3399 CPU:
- CPU family: ARM A72 + A53
- Platform bit depth: 64 bit
- Memory: 2 GB RAM
- Flash Storage: 16 GB
Audio
- TS connectors;
- Input impedance 1 MΩ
- TRS noise cancelling;
- Headphone output:
- 6.35mm TRS connector
- SPDIF output:
- 3.5mm coaxial TS connector (signal on tip port)
Each input/output uses a TRS connector, a True Bypass circuit, and has a LED whose color depends on the audio signal amplitude. Learn more about the Duo X here.
Control Voltage
- 2 CV input ports
- Switchable to CV Expression (you can use this input to connect one expression pedal)
- Stereo 6.35mm TRS connector
- 2 CV output port
Note:
- On the Duo X Limited edition, both the CV inputs and outputs have a range from 0V to 5V.
- On the Duo X normal production edition, both the CV inputs and outputs have a range from 0V to 10V.
Important Wrong use of the CV ports may damage the MOD Duo X. Please pay special attention.
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Device
- Connector: Type-B
- Standard: USB 2.0
Device Controller
- 1x 2.8" LCD display
- 2x endless knobs
- 3x performance buttons
- 8x knobs
- 4x push buttons switches with color LEDs
Software
The MOD Duo X runs the MOD runs latest Operating System. Support for the MOD Duo X was added to the MOD OS on version 1.7.
