MOD Dwarf Technical Specs
Technical specs
- length: 105 mm
- width: 202 mm
- height: 54 mm
Processor
- RockChip PX30 CPU:
- CPU family: Cortex-A35
- Platform bit depth: 64 bit
- Memory: 1 GB RAM
- Flash Storage: 8 GB
Audio
- Input impedance 1 MΩ
- Headphone output:
- 3.5mm TRS Stereo connection
- 2x105mW @ 16 ohms
- Mirrors main output
USB
- USB Host
- Connector: Type-A
- Standard: USB 2.0
- USB Device
- Connector: Type-B
- Standard: USB 2.0
Device Controller
- 1x 2.9" LCD display
- 3x endless knobs
- 3x push buttons (backlit with colour LEDs)
- 1x menu button (backlit with colour LEDs)
- 3x footswitches with coloured indicator LEDs
Software
The MOD Dwarf runs the latest Operating System. Support for the MOD Dwarf was added to the MOD OS on version 1.10.
