Revision as of 15:33, 10 December 2013 by Luis Fagundes (talk | contribs) (Translate to english, that will be the main language. We'll put the old page as translation of this one.)
<languages/>
<translate> In this page you find instructions to connect your computer to MOD.
Mac OS
3. Click the "Pair" button
4. In case a PIN is requested, use 1234. Depending on the Bluetooth version, the PIN won't be necessary.
Windows 7
2. From the Control Panel, go to "Devices and Printers". In this window, click in "Add device" button, located at the top left window corner.
3. Wait for your MOD to appear as one of the available devices, according to the picture below.
4. Select the MOD device and click in "Next"
5. In case a PIN is requested, use 1234. Depending on the Bluetooth version, the PIN won't be necessary.
6. Wait for the pairing process to finish and then close the window.
6. Back to the "Devices and printers" screen, right click on MOD and select "Connect using" > "Access point", according to the picture below.
7. That's it. Open Google Chrome and go to http://192.168.50.1
Pair devices
  • There's a default applet in Ubuntu for that
  • You can use bluez-simple-agent
Creating the network
  • sudo apt-get install bluez-compat
  • sudo pand --connect 00:15:83:3D:0A:57 -n
  • sudo dhclient bnep0
That's it, you can open your browser and go to http://192.168.50.1 </translate>
