Delay
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| avocado (2.0-6) |
11.9 |
11.9 |
12 |
11.6
| Bollie (2.6-6) |
13 |
13 |
12.5 |
12.5
| Bollie Delay XT (0.1-1) |
13.1 |
11.8 |
13.5 |
13.5 |
14.8 |
14.1
15.8 |
15.8 |
24 |
16
16.2 |
16.2 |
24.1 |
16
| Gaffa (1.1-4) |
18.9 |
18.9 |
22.6 |
21.9
| TTAP (2.2-13) |
25.6 |
25.6 |
| MDA DubDelay (0.7-16) |
12.2 |
12.2 |
11.8 |
11.8
| floaty (2.0-10) |
14.2 |
14.2 |
16.5 |
16.3
| dm-GrainDelay (0.0-4) |
16.7 |
16.7 |
| Granulator (1.0-6) |
20.2 |
20.2 |
32.2 |
31.8
| GxDelay-Stereo (28.3-24) |
12.7 |
12.7 |
12.8 |
12.7
| Gxdigital_delay (28.3-24) |
13.8 |
13.8 |
15 |
14.8
15.9 |
15.9 |
18.1 |
17.9
| Gxduck_delay (28.3-24) |
11.9 |
11.9 |
| Gxduck_delay_st (28.3-24) |
15.4 |
15.4 |
16.6 |
16.5
| GxEcho-Stereo (28.3-24) |
12.4 |
12.4 |
12.8 |
12.6
| GxEchoCat (28.3-23) |
15.7 |
15.7 |
18.2 |
18
18.4 |
184 |
22.9 |
22.7
11.8 |
11.8 |
11.4 |
11.4
11.8 |
11.8 |
11.2 |
10.8
Distortion
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| Open Big Muff (0.0-8) |
17 |
17 |
| CollisionDrive (1.3-2) |
17 |
9 |
| MDA Degrade (0.2-4) |
10 |
10 |
| DS1 (0.0-8) |
19 |
19 |
| GxBaJaTubeDriver (35.0-5) |
12 |
9 |
12 |
12 |
| GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
| GxHogsFoot (28.3-24) |
10 |
10 |
| GxHyperion (28.3-8) |
10 |
10 |
| GxKnightFuzz (34.0-8) |
11 |
10 |
| GxMole (28.3-24) |
10 |
10 |
| GxRangemaster (28.3-24) |
10 |
10 |
| GxSD2Lead (34.0-5) |
13 |
10 |
| GxTubeScreamer (28.3-24) |
11 |
11 |
| Schrammel OJD (8.9-6) |
27 |
10 |
| ChowCentaur (2.4-7) |
18 |
10 |
Dynamics
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| TAP Equalizer (7.2-11) |
10 |
10 |
| TAP Equalizer/BW (7.2-11) |
11 |
11 |
13 |
13 |
14 |
14 |
| rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
| Plugin (version) |
Dwarf x1 plugin |
Dwarf x20 plugins |
Duo X x1 |
Duo X x20 |
Duo x1 |
Duo x20
| the infamous mindi (0.1-9) |
8.4 |
20.1 |
Modulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| AmpVTS (v.1:9.24-13) |
21 |
21 |
25.3 |
24.9
| GxAlembic (v.1:28.3-25) |
12 |
12 |
13.5 |
13.2
| GxAmplifier-X (v.1:28.3-24) |
24.5 |
24.5 |
| GxAmplifier Stereo (v.1:28.3-24) |
37.4 |
37.4 |
| GxJCM800pre (v.1:28.3-24) |
37 |
37 |
| GxJCM800pre ST (v.1:28.3-24) |
38 |
38 |
| GxSupersonic (v.1:35.0-3) |
14.7 |
9.7 |
| GxSVT (v.1:34.0-7) |
16.2 |
9.7 |
| GxUVox720k (v.1:34.0-6) |
15.6 |
15.6 |
| GxVBassPreAmp (v.1:34.0-4) |
15.9 |
9.8 |
| GxVMK2 (v.1:34.0-4) |
14.4 |
14.4 |
| Mutant (v.1:3.0-3) |
20.9 |
20.9 |
38.6 |
38.4
| Mutant (drive on) (v.1:3.0-3) |
26.9 |
25.4 |
47.2 |
45.9
| Onyx (v.1:1.0-7) |
11.9 |
11.9 |
| PowerAmpImpulses (v.1:1.1-3) |
17.2 |
9.7 |
| PowerAmpTubes (v.1:1.1-3) |
10.9 |
9.7 |
| PreAmpImpulses (v.1:1.1-3) |
15.5 |
9.7 |
| PreAmpTubes (v.1:1.1-3) |
13.1 |
9.7 |
| ModularAmpToolKit (4 plugin) (v.1:1.1-3) |
30.4 |
20.3 |
| Rambler (clean) (v.1:2.1-2) |
22 |
22 |
| Rambler (lead) (v.1:2.1-2) |
24.2 |
24.2 |
| Red Apple (v.1:2.2-3) |
30.3 |
30.3 |
| GxRedeye Vibro Chump (v.1:28.3-24) |
25.2 |
25.2 |
| Roamer (v.1:1.2-1) |
18.2 |
18.2 |
| Aida-X (AMP Twin Custom 1 or 2) (v.1.0-14) |
34.1 |
12 |
| Aida-X (AMP Twin Vintage 1 & 2) (v.1.0-14) |
34.1 |
12 |
| NAM (AMP Twin Custom 1 or 2) (v.1.0-17) |
66.8 |
11.6 |
| NAM (AMP Twin Vintage 1 & 2) (v.1.0-17) |
67.7 |
11.6 |
| Aida Vibro Super Light (v.1.1-11) |
23.2 |
11.8 |
| Aida Vibro Light (v.1.1-11) |
28.4 |
11.8 |
| Aida Vibro Standard (v.1.1-11) |
41.2 |
11.8 |
| Aida Tweaker Light (v.1.0-6) |
34.3 |
34.2 |
| Aida Tweaker Standard (v.1.0-6) |
41.3 |
34.2 |
| Aida Tweaker Heavy (v.1.0-6) |
49.2 |
34.2 |
| Aida JCVM Light CLEAN & CRUNCH & ROCK (v.1.1-7) |
29 |
11.6 |
| Aida JCVM Light LEAD & METAL (v.1.1-7) |
41.8 |
11.6 |
| Aida JCVM Light SLX (v.1.1-7) |
34.4 |
11.6 |
| Aida JCVM Standard CLEAN & CRUNCH & ROCK (v.1.1-7) |
41.7 |
11.6 |
| Aida JCVM Standard LEAD & METAL (v.1.1-7) |
46.1 |
11.6 |
| Aida JCVM Standard SLX (v.1.1-7) |
41.5 |
11.6 |
| Aida JCVM Heavy CLEAN & CRUNCH & ROCK (v.1.1-7) |
51.8 |
11.6 |
| Aida JCVM Heavy LEAD & METAL (v.1.1-7) |
52.3 |
11.6 |
| Aida JCVM Heavy SLX (v.1.1-7) |
51.5 |
11.6 |
Spatial
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
11.6 |
11.6 |
11.6 |
11.6 |
9.1 |
9.1 |
| Gain (1.0-18) |
11.6 |
11.6 |
| Gain 2x2 (1.0-18) |
11.8 |
11.8 |
| TinyGain Mono (770.0-7) |
14.6 |
14.6 |
| TinyGain Stereo (770.0-7) |
14.9 |
14.9 |
| Volume (1.0-7) |
11.5 |
11.5 |
| Volume 2x2 (1.0-7) |
11.6 |
11.6 |
| Level Meter (0.0-1) |
11.3 |
11.3 |
| LP3 Basic (1.0-15) |
16.1 |
14.6 |
| Metronome (1.0-5) |
9 |
9 |
| Mixer (2.0-4) |
22.2 |
22.2 |
| Mixer Stereo (2.0-4) |
34.1 |
28.4 |
| Notes (2.0-3) |
8.2 |
8.2 |
| Spectrum Analyzer (1.0-1) |
9.5 |
9.3 |
| Stereo X-Fade (516.0-6) |
11.8 |
11.8 |
| Switchbox 1-2 (1.1-18) |
11.4 |
11.4 |
| Switchbox 1-2 ST (1.1-6) |
12.2 |
12.2 |
| Switchbox 2-1 (1.1-6) |
11.6 |
11.6 |
| Switchbox 2-1 ST (1.1-6) |
11.8 |
11.8 |
| SwitchTrigger4 (1.1-12) |
11.9 |
11.9 |
| ToggleSwitch (1.1-18) |
12 |
12 |
| Instrument Tuner (0.0-1) |
77.3 |
58.4 |
Control Voltage
| Plugin (version) |
Dwarf x1 plugin |
Dwarf x20 plugins |
Duo X x1 |
Duo X x20 |
Duo x1 |
Duo x20
| Control to CV (3.0-17) |
8.3 |
19 |
| CV Parameter Modulation |
8.3 |
32.2 |
| Slew Rate Limiter (1.0-14) |
8.3 |
32.5 |
