Delay
avocado (2.0-6) |
11.9 |
11.9 |
12 |
11.6
Bollie (2.6-6) |
13 |
13 |
12.5 |
12.5
Bollie Delay XT (0.1-1) |
13.1 |
11.8 |
Calf Vintage Delay (60.0-8) |
13.5 |
13.5 |
14.8 |
14.1
Invada Delay Munge (mono in) (2.1-8) |
15.8 |
15.8 |
24 |
16
Invada Delay Munge (sum L+R in) ( 2.1-8) |
16.2 |
16.2 |
24.1 |
16
Gaffa (1.1-4) |
18.9 |
18.9 |
22.6 |
21.9
TTAP (2.2-13) |
25.6 |
25.6 |
MDA DubDelay (0.7-16) |
12.2 |
12.2 |
11.8 |
11.8
floaty (2.0-10) |
14.2 |
14.2 |
16.5 |
16.3
dm-GrainDelay (0.0-4) |
16.7 |
16.7 |
Granulator (1.0-6) |
20.2 |
20.2 |
32.2 |
31.8
GxDelay-Stereo (28.3-24) |
12.7 |
12.7 |
12.8 |
12.7
Gxdigital_delay (28.3-24) |
13.8 |
13.8 |
15 |
14.8
Gxdigital_delay_st (28.3-24) |
15.9 |
15.9 |
18.1 |
17.9
Gxduck_delay (28.3-24) |
11.9 |
11.9 |
Gxduck_delay_st (28.3-24) |
15.4 |
15.4 |
16.6 |
16.5
GxEcho-Stereo (28.3-24) |
12.4 |
12.4 |
12.8 |
12.6
GxEchoCat (28.3-23) |
15.7 |
15.7 |
18.2 |
18
GxMultiBandDelay (28.3-24) |
18.4 |
184 |
22.9 |
22.7
the infamous stuck (0.1-13) |
11.8 |
11.8 |
11.4 |
11.4
the infamous stuck stacker (0.1-13) |
11.8 |
11.8 |
11.2 |
10.8
Distortion
Open Big Muff (0.0-8) |
17 |
17 |
CollisionDrive (1.3-2) |
17 |
9 |
MDA Degrade (0.2-4) |
10 |
10 |
DS1 (0.0-8) |
19 |
19 |
GxBaJaTubeDriver (35.0-5) |
12 |
9 |
GxColorSoundTonebender (28.3-24) |
12 |
12 |
GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
GxHogsFoot (28.3-24) |
10 |
10 |
GxHyperion (28.3-8) |
10 |
10 |
GxKnightFuzz (34.0-8) |
11 |
10 |
GxMole (28.3-24) |
10 |
10 |
GxRangemaster (28.3-24) |
10 |
10 |
GxSD2Lead (34.0-5) |
13 |
10 |
GxTubeScreamer (28.3-24) |
11 |
11 |
Schrammel OJD (8.9-6) |
27 |
10 |
ChowCentaur (2.4-7) |
18 |
10 |
Dynamics
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
TAP Equalizer (7.2-11) |
10 |
10 |
TAP Equalizer/BW (7.2-11) |
11 |
11 |
x42-eq - Parametric Equalizer Mono (1.1-6) |
13 |
13 |
x42-eq - Parametric Equalizer Stereo (1.1-6) |
14 |
14 |
rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Modulator
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
AmpVTS (v.1:9.24-13) |
21 |
21 |
25.3 |
24.9
GxAlembic (v.1:28.3-25) |
12 |
12 |
13.5 |
13.2
GxAmplifier-X (v.1:28.3-24) |
24.5 |
24.5 |
GxAmplifier Stereo (v.1:28.3-24) |
37.4 |
37.4 |
GxJCM800pre (v.1:28.3-24) |
37 |
37 |
GxJCM800pre ST (v.1:28.3-24) |
38 |
38 |
GxSupersonic (v.1:35.0-3) |
14.7 |
9.7 |
GxSVT (v.1:34.0-7) |
16.2 |
9.7 |
GxUVox720k (v.1:34.0-6) |
15.6 |
15.6 |
GxVBassPreAmp (v.1:34.0-4) |
15.9 |
9.8 |
GxVMK2 (v.1:34.0-4) |
14.4 |
14.4 |
Mutant (v.1:3.0-3) |
20.9 |
20.9 |
38.6 |
38.4
Mutant (drive on) (v.1:3.0-3) |
26.9 |
25.4 |
47.2 |
45.9
Onyx (v.1:1.0-7) |
11.9 |
11.9 |
PowerAmpImpulses (v.1:1.1-3) |
17.2 |
9.7 |
PowerAmpTubes (v.1:1.1-3) |
10.9 |
9.7 |
PreAmpImpulses (v.1:1.1-3) |
15.5 |
9.7 |
PreAmpTubes (v.1:1.1-3) |
13.1 |
9.7 |
ModularAmpToolKit (4 plugin) (v.1:1.1-3) |
30.4 |
20.3 |
Rambler (clean) (v.1:2.1-2) |
22 |
22 |
Rambler (lead) (v.1:2.1-2) |
24.2 |
24.2 |
Red Apple (v.1:2.2-3) |
30.3 |
30.3 |
GxRedeye Vibro Chump (v.1:28.3-24) |
25.2 |
25.2 |
Roamer (v.1:1.2-1) |
18.2 |
18.2 |
Aida-X (AMP Twin Custom 1 or 2) (v.1.0-14) |
34.1 |
12 |
Aida-X (AMP Twin Vintage 1 & 2) (v.1.0-14) |
34.1 |
12 |
NAM (AMP Twin Custom 1 or 2) (v.1.0-17) |
66.8 |
11.6 |
NAM (AMP Twin Vintage 1 & 2) (v.1.0-17) |
67.7 |
11.6 |
Aida Vibro Super Light (v.1.1-11) |
23.2 |
11.8 |
Aida Vibro Light (v.1.1-11) |
28.4 |
11.8 |
Aida Vibro Standard (v.1.1-11) |
41.2 |
11.8 |
Aida Tweaker Light (v.1.0-6) |
34.3 |
34.2 |
Aida Tweaker Standard (v.1.0-6) |
41.3 |
34.2 |
Aida Tweaker Heavy (v.1.0-6) |
49.2 |
34.2 |
Aida JCVM Light CLEAN & CRUNCH & ROCK (v.1.1-7) |
29 |
11.6 |
Aida JCVM Light LEAD & METAL (v.1.1-7) |
41.8 |
11.6 |
Aida JCVM Light SLX (v.1.1-7) |
34.4 |
11.6 |
Aida JCVM Standard CLEAN & CRUNCH & ROCK (v.1.1-7) |
41.7 |
11.6 |
Aida JCVM Standard LEAD & METAL (v.1.1-7) |
46.1 |
11.6 |
Aida JCVM Standard SLX (v.1.1-7) |
41.5 |
11.6 |
Aida JCVM Heavy CLEAN & CRUNCH & ROCK (v.1.1-7) |
51.8 |
11.6 |
Aida JCVM Heavy LEAD & METAL (v.1.1-7) |
52.3 |
11.6 |
Aida JCVM Heavy SLX (v.1.1-7) |
51.5 |
11.6 |
Spatial
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
Auto Output Selector (1.0-6) |
11.6 |
11.6 |
Auto Input Selector (1.0-6) |
11.6 |
11.6 |
C* Click - Metronome (9.24-13) |
9.1 |
9.1 |
Gain (1.0-18) |
11.6 |
11.6 |
Gain 2x2 (1.0-18) |
11.8 |
11.8 |
TinyGain Mono (770.0-7) |
14.6 |
14.6 |
TinyGain Stereo (770.0-7) |
14.9 |
14.9 |
Volume (1.0-7) |
11.5 |
11.5 |
Volume 2x2 (1.0-7) |
11.6 |
11.6 |
Level Meter (0.0-1) |
11.3 |
11.3 |
LP3 Basic (1.0-15) |
16.1 |
14.6 |
Metronome (1.0-5) |
9 |
9 |
Mixer (2.0-4) |
22.2 |
22.2 |
Mixer Stereo (2.0-4) |
34.1 |
28.4 |
Notes (2.0-3) |
8.2 |
8.2 |
Spectrum Analyzer (1.0-1) |
9.5 |
9.3 |
Stereo X-Fade (516.0-6) |
11.8 |
11.8 |
Switchbox 1-2 (1.1-18) |
11.4 |
11.4 |
Switchbox 1-2 ST (1.1-6) |
12.2 |
12.2 |
Switchbox 2-1 (1.1-6) |
11.6 |
11.6 |
Switchbox 2-1 ST (1.1-6) |
11.8 |
11.8 |
SwitchTrigger4 (1.1-12) |
11.9 |
11.9 |
ToggleSwitch (1.1-18) |
12 |
12 |
Instrument Tuner (0.0-1) |
77.3 |
58.4 |
Control Voltage
Control to CV (3.0-17) |
8.3 |
19 |
