Audio Through USB
Using USB Audio Gadget
NOTE: This is EXPERIMENTAL
touch /data/enable-usb-multi-gadget
touch /data/enable-usb-audio-gadget
# if using windows, also run:
touch /data/enable-usb-windows-compatNow we reboot
sync && hmi-reset && rebootSome caveats and known issues:
Forum Threads:
Windows specific tweaks
When picking an audio driver/mode look for "WASAPI" or "Windows Audio". If there is an option for "exclusive mode" try that first; it won't allow other applications to use the usb audio device but cuts the roundtrip latency in half.
Under this WASAPI/Windows-Audio mode with 512 buffer size we have measure roundtrip latencies of around 80ms in normal/shared mode, and 65ms in exclusive mode.
Latency decreases if you use the MOD unit analog IO.
ASIO4ALL
Using ASIO4ALL has been confirmed to work, but needs some tweaks: - Set buffer size to 128 or higher - In advanced settings set buffer offset to 16ms - Turn off all other options in advanced settings
FL Studio ASIO
The FL Studio ASIO driver has also been confirmed to work, no special tweaks needed. Its minimum buffer size of 256 should work fine as-is.
It gives a total roundtrip latency of around 75ms, will be less if you use the MOD unit analog IO.
Using netJACK2
sudo ufw allow 19000Then, ssh into the unit, and run:
touch /data/enable-netmanager
systemctl start jack-netmanagerNOTE: You only need to run this command once. The next time the unit boots, jack-netmanager will be loaded by default. Delete the /data/enable-netmanager file inside the unit to remove this auto-start feature.
Now run jackd on your own computer (connected to the unit via USB), like this:
jackd -R -P 80 -d net -a 192.168.51.1 -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -sAdjust the parameters as needed, but keep mod-slave as the client name.
Parameters explained
| -a | Multicast address, in this case the IP address of the MOD unit. |
| -C | Number of audio input ports on the slave. This determines the number of audio output ports on the MOD unit, marked as "Hardware Audio To Slave" ports in the web interface. |
| -P | Number of audio output ports on the slave. This determines the number of audio input ports on the MOD unit, marked as "Hardware Audio From Slave" ports in the web interface. |
| -i | Number of MIDI input ports on the slave. This determines the number of MIDI output ports on the MOD unit, marked as "Hardware Midi To Slave" ports in the web interface. |
| -o | Number of MIDI output ports on the slave. This determines the number of MIDI input ports on the MOD unit, marked as "Hardware Midi From Slave" ports in the web interface. |
jack_control dps latency 4
jack_control start
