Delay
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| avocado (2.0-6) |
11.9 |
11.9 |
| Bollie (2.6-6) |
13 |
13 |
| Bollie Delay XT (0.1-1) |
13.1 |
11.8 |
13.5 |
13.5 |
15.8 |
15.8 |
16.2 |
16.2 |
| Gaffa (1.1-4) |
18.9 |
18.9 |
| TTAP (2.2-13) |
25.6 |
25.6 |
| MDA DubDelay (0.7-16) |
12.2 |
12.2 |
| floaty (2.0-10) |
14.2 |
14.2 |
| dm-GrainDelay (0.0-4) |
16.7 |
16.7 |
| Granulator (1.0-6) |
20.2 |
20.2 |
| GxDelay-Stereo (28.3-24) |
12.7 |
12.7 |
| Gxdigital_delay (28.3-24) |
13.8 |
13.8 |
15.9 |
15.9 |
| Gxduck_delay (28.3-24) |
11.9 |
11.9 |
| Gxduck_delay_st (28.3-24) |
15.4 |
15.4 |
| GxEcho-Stereo (28.3-24) |
12.4 |
12.4 |
| GxEchoCat (28.3-23) |
15.7 |
15.7 |
18.4 |
184 |
11.8 |
11.8 |
11.8 |
11.8 |
Distortion
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| Open Big Muff (0.0-8) |
17 |
17 |
| CollisionDrive (1.3-2) |
17 |
9 |
| MDA Degrade (0.2-4) |
10 |
10 |
| DS1 (0.0-8) |
19 |
19 |
| GxBaJaTubeDriver (35.0-5) |
12 |
9 |
12 |
12 |
| GxFuzzFaceJH-2 (28.3-24) |
13 |
13 |
| GxHogsFoot (28.3-24) |
10 |
10 |
| GxHyperion (28.3-8) |
10 |
10 |
| GxKnightFuzz (34.0-8) |
11 |
10 |
| GxMole (28.3-24) |
10 |
10 |
| GxRangemaster (28.3-24) |
10 |
10 |
| GxSD2Lead (34.0-5) |
13 |
10 |
| GxTubeScreamer (28.3-24) |
11 |
11 |
Dynamics
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Filter
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
| TAP Equalizer (7.2-11) |
10 |
10 |
| TAP Equalizer/BW (7.2-11) |
11 |
11 |
13 |
13 |
14 |
14 |
| rkr Parametric EQ (0.0-7) |
12 |
12 |
Generator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
MIDI utilisty
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Modulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Reverb
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Simulator
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Plugin (version) Dwarf % On Dwarf % Off Duo X % On Duo X % Off Duo % On Duo % Off
C* AmpVTS (v.1:9.24-13) 21 21
GxAlembic (v.1:28.3-25) 12 12
GxAmplifier-X (v.1:28.3-24) 24.5 24.5
GxAmplifier Stereo (v.1:28.3-24) 37.4 37.4
GxJCM800pre (v.1:28.3-24) 37 37
GxJCM800pre ST (v.1:28.3-24) 38 38
GxSupersonic (v.1:35.0-3) 14.7 9.7
GxSVT (v.1:34.0-7) 16.2 9.7
GxUVox720k (v.1:34.0-6) 15.6 15.6
GxVBassPreAmp (v.1:34.0-4) 15.9 9.8
GxVMK2 (v.1:34.0-4) 14.4 14.4
Mutant (v.1:3.0-3) 20.9 20.9
Mutant (drive on) (v.1:3.0-3) 26.9 25.4
Onyx (v.1:1.0-7) 11.9 11.9
PowerAmpImpulses (v.1:1.1-3) 17.2 9.7
PowerAmpTubes (v.1:1.1-3) 10.9 9.7
PreAmpImpulses (v.1:1.1-3) 15.5 9.7
PreAmpTubes (v.1:1.1-3) 13.1 9.7
ModularAmpToolKit (v.1:1.1-3) 30.4 20.3
Rambler (clean) (v.1:2.1-2) 22 22
Rambler (lead) (v.1:2.1-2) 24.2 24.2
Red Apple (v.1:2.2-3) 30.3 30.3
GxRedeye Vibro Chump (v.1:28.3-24) 25.2 25.2
Roamer (v.1:1.2-1) 18.2 18.2
Spatial
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Spectral
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
Utility
| Plugin (version) |
Dwarf % On |
Dwarf % Off |
Duo X % On |
Duo X % Off |
Duo % On |
Duo % Off
11.6 |
11.6 |
11.6 |
11.6 |
9.1 |
9.1 |
| Gain (1.0-18) |
11.6 |
11.6 |
| Gain 2x2 (1.0-18) |
11.8 |
11.8 |
| TinyGain Mono (770.0-7) |
14.6 |
14.6 |
| TinyGain Stereo (770.0-7) |
14.9 |
14.9 |
| Volume (1.0-7) |
11.5 |
11.5 |
| Volume 2x2 (1.0-7) |
11.6 |
11.6 |
| Level Meter (0.0-1) |
11.3 |
11.3 |
| LP3 Basic (1.0-15) |
16.1 |
14.6 |
| Metronome (1.0-5) |
9 |
9 |
| Mixer (2.0-4) |
22.2 |
22.2 |
| Mixer Stereo (2.0-4) |
34.1 |
28.4 |
| Notes (2.0-3) |
8.2 |
8.2 |
| Spectrum Analyzer (1.0-1) |
9.5 |
9.3 |
| Stereo X-Fade (516.0-6) |
11.8 |
11.8 |
| Switchbox 1-2 (1.1-18) |
11.4 |
11.4 |
| Switchbox 1-2 ST (1.1-6) |
12.2 |
12.2 |
| Switchbox 2-1 (1.1-6) |
11.6 |
11.6 |
| Switchbox 2-1 ST (1.1-6) |
11.8 |
11.8 |
| SwitchTrigger4 (1.1-12) |
11.9 |
11.9 |
| ToggleSwitch (1.1-18) |
12 |
12 |
| Instrument Tuner (0.0-1) |
77.3 |
58.4 |
